Subwoofer solutions
Old Feb 26, 2003 | 12:32 PM
  #21
MajorHavoc's Avatar
[QUOTE]Originally posted by modifry
[B]Some other posts about subs in this area talked about a "false bottom" in the passenger footwell.
Old Feb 26, 2003 | 02:00 PM
  #22
s2k_redhead's Avatar
MajorHavoc, I just noticed that you're in SoCal. Who did your install for that sub? I'm really starting to like this idea... If, for some reason, you wanted to take it out and return the car to "stock", would that hole be pretty easy to camoflague? I'm assuming since it's under the carpet, it's just hidden!? Do you know the dimensions of the hole itself?
Old Feb 26, 2003 | 03:05 PM
  #23
modifry's Avatar
Honorary Member
[QUOTE]Originally posted by TepEvan
[B]modify - you might want to look at either (a) image dynamics - they require a very small box OR (b) you could go with free air subs, ex. Kicker Competition Free Air and just go with a baffle.
I haven't decided what I want to do about a sub yet, I was thinking a 10" Eclipse Alum or Tita, but more recently I've been thinking about going ported.
Old Feb 26, 2003 | 06:57 PM
  #24
MajorHavoc's Avatar
Removal would be easy. I would use the flat metal grill under the carpet to cover the hole!
And, sorry, I didn't measure or even take a picture of the hole!! Doh!!!
The place that installed it is Wired For Sound in Orange County.
Old Feb 27, 2003 | 10:11 AM
  #25
S2kRob's Avatar
I wonder if you could do a single 8" in the passenger side footwell without sacrificing much leg room and not cutting the car?
Old Mar 8, 2003 | 12:59 PM
  #26
b0mbrman's Avatar
There are some 10" subs that don't need very much mounting depth...CDT MS-100, IDQ's, Blaupunkt...Even the e10k isn't so bad...
Old Mar 8, 2003 | 03:32 PM
  #27
Cyber Logic's Avatar
Here are the pictures from the 10" Carbon Fiber Sub's in my floor. The mounting depth of the subs is 2.9". This is absolutely the way to go if you can get a sub this shallow. Also I have phenominal bass (Bass that would prolly beat rival most of the higher ends systems on this site) even when I have the subs turned off. This was done by enclosing 2 sets of 6" speakers in the kick panels. By havin the speakers enclosed they sound like there are 10" subs in the kicks and play mid bass that makes your heart stop. You don't necessarily need a huge sub to create bass...it's all in the enclosure and sub design. For more info on my setup goto here.
Old Mar 8, 2003 | 03:40 PM
  #28
[B]They'd have to be pretty shallow subs to clear the seat bottom, or does he have the seats positioned and not move them?
I used to have an 8" sub in the floor of my Chevy S10, and it was pretty impressive for a single 8, so I know it's a 'sound' installation option.
Old Mar 9, 2003 | 08:53 PM
  #29
pierceman's Avatar
modifry, see Cyber Logic's post, the subs hang under the car with the same clearance as the exhaust. Crazy set up. that is the one I was talking about earlier, the seats are fully active..
Matt
Old Mar 9, 2003 | 08:56 PM
  #30
pierceman's Avatar
the square subs from kicker are for tight areas and do not need as much space to work. solobaricks I think.
