Switched Source
Old Jul 12, 2011 | 02:40 PM
starrman's Avatar
Default Switched Source
I am installing 2 gauges and a pump for my FMIC, I found one switched source in the underdash fuse box, the two identical terminals above I thought were switched sources, but apparently not. One was constant power and the other did not give me anything? I am an electrical idiot and probably should not be attempting this, but hey what better way to learn. Can anyone give me some direction on where to hook up the other two leads? Thanks!
Old Jul 12, 2011 | 07:36 PM
oth's Avatar
oth
One is constant, one with the key, one with the lights on.
from the UK technical FAQ, I believe originally courtesy of Modifry
Why do you need three separate switched sources? Unless you are drawing a lot of current you
should be able to connect all three to one source.
You should make sure that whatever you are connecting to those terminals have their own fuses.
Old Jul 13, 2011 | 05:40 AM
starrman's Avatar
Thanks Oth, I am connecting a water pump for the FMIC and two seperate gauges. I have the pump on C (below)so it works fine, I didn't know I could hook all three up to that one terminal. I had just put a female terminal connector on the end of the wire, not sure how to get all 3 on one? Also, would I just buy 3 inline fuses and put them inbetween the devices and the terminal?
Old Jul 13, 2011 | 06:54 AM
ungucpho's Avatar
you can use a relay, tap D for constant, C for switched, ground the relay and the switched source from the relay should be able to power all 3 sources
Old Jul 13, 2011 | 08:28 AM
oth's Avatar
oth
quoting Modifry, from this thread:
Both the "constant" and "ignition" terminals are fused by fuse 42 in the under-hood fuse box. It's a 40 or 50 AMP
fuse (can't remember). That's why you should always use an in-line fuse when connecting to these terminals. From
this terminal you could short an 18-gauge wire to ground and instead of blowing the fuse it would just melt the
wire (in about 2 seconds).
BTW - connector E (lights) is fused by fuse 23, 10 amps.
The constant and ignition terminals are off the same fuse, so there is no particular reason to split them
for the different inputs.
I'd run wire(s) to a spade connector that slips onto the fusebox spade, then to 1, 2, or 3 (depending on how
obsessive you are) inline fuses (or a fuse/distribution block), and from the fuse(s) to the the pump and gauges.
Radio Shack has an assortment of fuse holders to choose from.
The two gauges probably draw very little current, and you should use a low-amperage fuse for them, while the pump
draws more and you'll need a higher amp fuse for it. Hopefully you have some specs that will tell you exactly what
the current draw is.
Old Jul 13, 2011 | 11:33 AM
starrman's Avatar
Thanks again OTH, I am on a mission!
KLASMID
Nov 29, 2020 04:33 PM
for_my_s2k
Jul 27, 2013 06:09 PM
954chris
Dec 31, 2012 06:57 AM
Predator
Dec 26, 2009 11:12 AM
dhess
Jan 19, 2002 08:35 PM
