Top down without the parking brake?
Old Jul 25, 2003 | 12:18 PM
  #21
SC_Highlander's Avatar
I have the same DCI. The wire in question carries the signal from the speed sensor to the convertible top module. If you cut it between your connection to the DCI and the top module, you'll be fine. I took the connector apart and remove the whole wire and pin from the connector.
Old Jul 25, 2003 | 02:52 PM
  #22
petraidm's Avatar
Dumb quesstion ... Why would you want to defeat this safety feature for anyway???
Old Jul 25, 2003 | 03:45 PM
  #23
In my case, I got caught in a sudden rain in the middle of atlanta traffic. I could not get over to the shoulder, and we were traveling at about 15-20 mph. I got soaked before I could get over to the shoulder, stop, put on the e-brake and put the top up. Bypassing the speed sensor would have let me pull up the e-brake one click, then raise the top before getting completely soaked.
Old Jul 26, 2003 | 06:31 AM
  #24
ruexp67's Avatar
More than once, I have started the car, released the brake, and THEN tried to operate the top (even though I was stopped) Grrr!
Although operating it while pulling to a stop in a parking lot, would save me a lot of time.
Part of me wants to disable both, but I am sure that would not be wise.
Thanks for the info SC_Highlander.
Old Jul 26, 2003 | 07:03 PM
  #25
modifry's Avatar
Honorary Member
[QUOTE]Originally posted by ruexp67
[B]More than once, I have started the car, released the brake, and THEN tried to operate the top (even though I was stopped)
Old Jul 28, 2003 | 04:56 AM
  #26
Squeezer's Avatar
so how do you disable the ebrake?
Old Jul 28, 2003 | 05:03 AM
  #27
GamecockS2K's Avatar
See SC_Highlander's post: https://www.s2ki.com/forums/showthre...threadid=138773
Old Jul 28, 2003 | 12:05 PM
  #28
Nside's Avatar
https://www.s2ki.com/forums/showthread.php?...threadid=138773
Old Jul 28, 2003 | 12:12 PM
  #29
ruexp67's Avatar
Originally posted by modifry
You can always hide a toggle switch somewhere so if anyone but you is driving the car (dealer, spousal unit) you could enable the speed safety.
Mmmm...... You may be on to something here. I need to figure out a good place to mount a small switch. Mabey I can find something small enough to go near the HU, or perhaps just hidden under the driver's dash. Mmm.... Glove Box.
Now you have me thinking!
Old Jul 28, 2003 | 12:37 PM
  #30
Dante(suzuka)'s Avatar
What about the passenger window shut off? That little switch on the drivers door that is suppose to limit the passenders window. That could be an optimal spot for a safety swith, just mess with the wires a little.
