Top down without the parking brake?
Old Aug 6, 2003 | 06:20 AM
  #81
Dante(suzuka)'s Avatar
And what about the VSS splice for Lucids DCI controls? WIll this affect it at all? Would you just cut the wire, tape one end, and splice the other end to the DCI?
Old Aug 6, 2003 | 06:33 AM
  #82
GamecockS2K's Avatar
Check this thread out:
https://www.s2ki.com/forums/showthread.php?...threadid=138773
-Garrett
Old Aug 6, 2003 | 06:56 AM
  #83
PJK3's Avatar
[QUOTE]Originally posted by ruexp67
[B]You could also just "one-click" the ebrake on.
Old Aug 6, 2003 | 07:01 AM
  #84
SC_Highlander's Avatar
If you cut the VSS wire for the top module, splice the wire for the DCI into the side that is not still attached to the top module. Splice it into the side that runs back up under the dash.
  #85
[QUOTE]Originally posted by PJK3
[B]btw, between the various times i've run wire up under the passenger side of the dash, i finally broke some clips on the dash panel and slightly cracked the panel...
Old Aug 6, 2003 | 07:11 AM
  #86
PJK3's Avatar
[QUOTE]Originally posted by GamecockS2K
[B]
Well, at least it's not an expensive panel...
Old Aug 6, 2003 | 07:22 AM
  #87
I just basically push the clips out of the square from behind. You should easily be able to just slide your fingers up under the panel and feel the bottom clips. Pull on the panel lightly with one hand and push those clips out, one at a time, with the other. It will put a lot less stress on the panel and you'll find that you'll be worrying less about the whole thing just cracking at any moment!
Hopefully this makes a little more sense...
Old Aug 6, 2003 | 07:49 AM
  #88
PJK3's Avatar
i wasn't trying to dislodge the clips from behind previously... i was just popping them out one at a time...
thanks!
Old Aug 7, 2003 | 08:08 AM
  #89
modifry's Avatar
Honorary Member
[B]. . . i finally broke some clips on the dash panel and slightly cracked the panel...
Old Aug 8, 2003 | 05:02 AM
  #90
PJK3's Avatar
[QUOTE]Originally posted by modifry
[B]I put a huge crack in mine a while back - taking it off in 15 degree weather - I guess the plastic is more brittle at low temps.
Anyway - I actually use TOOLS
