uninstall VAFC II
Old May 8, 2006 | 12:38 PM
wils2k's Avatar
Default uninstall VAFC II
i wanted to take off my VAFC II...do i just pull out all the wires??
do i need to reset my ECU?? helppp
Old May 8, 2006 | 12:39 PM
darkfx's Avatar
Who installed it? Do you have a harness?
Old May 8, 2006 | 12:42 PM
wils2k's Avatar
a shop installed it while i was doing a dyno...no harness...wires spiked into my ECU...
Old May 8, 2006 | 01:05 PM
darkfx's Avatar
I've done about a dozen install/uninstalls.. Most of the wires except for 2 are directly spliced in.. There are 2 that are totally cut.. the VTEC signal wire, and i believe the second is the pressure signal wire(pink/purple on the VAFC harness).. you will need to re-attatch the wires together after you remove the wires on each of them. If you are clueless on how to do this, its better to pay someone because you do NOT want to mess up your ECU. Post up if you have anymore questions.
Old May 8, 2006 | 02:01 PM
Wisconsin S2k's Avatar
moving to electrical
Mercuri
Dec 10, 2008 11:44 AM
darkfx
Feb 22, 2006 08:16 AM
TwiztedS2K
Feb 24, 2005 06:48 AM
Kyps_Sabre
Apr 12, 2004 07:05 AM
nownor
Apr 10, 2003 05:35 PM
