Using a fuse holder to connect audio cable.
Old May 14, 2007 | 07:02 PM
tbonesteak's Avatar
Default Using a fuse holder to connect audio cable.
Hey Guys,
I relocated everything and reinstalled my system today. To extend my 4 gauge wire, i used a fuse holder with 4 gauge wire on one end and an 8 gauge wire on the other end. I did this because my system is running 350 watt rms and 8 gauge would be more than sufficient (my ground wire is 8 gauge as well). Well..after that, i connected everything and turned it on, but the amp wouldnt power up. I dont think it's the remote wire and i dont think it's the ground wire either. Is there something wrong with this setup? Thanks in advance.
Tim
Old May 14, 2007 | 08:30 PM
NFRs2000NYC's Avatar
No....from the description you provided, it sounds like you added another inline fuse to extend your cable. Is there a fuse in it? If so, double check that, and if its not then its either the ground or the remote.
Old May 15, 2007 | 03:39 AM
darkknight1999's Avatar
Use a multi meter and test it to see if your getting power to the amp.
Ajjra
Sep 28, 2009 04:17 AM
preppyS2000
Jul 30, 2007 06:35 AM
Will
Mar 2, 2006 09:00 AM
vampire
Jan 4, 2005 02:37 PM
145
Jul 9, 2002 09:56 AM
