Valentine 1 (V1) RJ-11
Old Jul 13, 2010 | 04:19 PM
GunNam's Avatar
Default Valentine 1 (V1) RJ-11
Anyone know if the V1 power cable (RJ-11) is exactly the same as a regular phone cable?
I can get power to the main unit, but if I use the RJ-11 (Non-V1) to connect the main unit to the Concealed Display, the Main unit does not see it (Main Unit lights up, but the concealed display does not).
The V1 site says I can make my own custom length, so I would assume it is the same as any RJ-11, but it's not working.
Any help would be appreciated. I'm so close to having everything set up.
Old Jul 13, 2010 | 05:03 PM
oth's Avatar
oth
Yes, a V1 power cable is the same as a regular phone cable, however...
...an RJ-11 jack has four conductors, but basic telephones only require
one pair, so some cheap phone cords have only two conductors in them.
The Valentine-supplied cords have four conductors, so my guess is it
needs four, at least to communicate with the concealed display.
If you are using a four-conductor phone wire, then I would guess there's
a flaw in the wire/RJ-11 plug.
Old Jul 13, 2010 | 06:35 PM
midnightmethane's Avatar
yep I can attest to that...the cheap phone wires won't work...I tested it with GE phone wires from Home Depot...didn't work...either get the proper cable from Valentine or look for a 4 connector wire
Old Jul 13, 2010 | 11:19 PM
GunNam's Avatar
I got the same one from Home Depot! It doesn't work! I got some random 4-wire one and the concealed display lights up, but the mute button doesn't work! When I test it with the coiled plug from my cig adapter and the power wire supplied from V1... voila, everything works great.
Anyone know "why" this is the case? I checked the colors on the V1 supplied cords and the colors are reversed from one RJ-11 plug to the RJ-11 plug on the other end. I verified the same on my 4-wire regular phone cord; the colors are reversed from one plug to the plug on the other end. Do I really have to order the V1 cable?
Old Jul 14, 2010 | 09:09 AM
I ended up using V1 cable...just suck up the shipping charge but hey at least you'll have a great working unit...some things you just have to bite the bullet on
Old Jul 14, 2010 | 01:05 PM
oth's Avatar
oth
you really shouldn't need one from Valentine. Look very carefully at
the conductors in the RJ11 plug, make sure nothing is bent, and that
the plug is seating correctly in the jack. Many old phone wires have
been tripped over so many times that they may not be fully intact.
Old Jul 15, 2010 | 04:46 PM
GunNam's Avatar
I ended up ordering the V1 power cable and sucking up the shipping charge of $0.00 USD. hahaha
oth: I bought a brand new one with 4-wires and it didn't work. 2 other old phone cables didn't work...
I emailed V1 about it, but haven't got a response back yet. I tried two 4-wire phone cables (1 old, 1 new), and one 2-wire cables with no luck. I conveniently had two V1 power cables (unfortunately 1 is the coiled one), and they work perfectly.
(In all the little tests I ran, they all powered the main unit just fine. It only fails to function correctly when hooking up the Concealed display)
Ronss2k
Jun 6, 2010 09:55 AM
u8myrice
Mar 3, 2009 08:28 PM
dmw16
Jul 3, 2006 10:06 AM
crogers
Sep 24, 2003 03:08 PM
Rick Hesel
Jun 24, 2003 04:21 AM
