valentine hardwiring
Old Jul 4, 2003 | 06:42 AM
J MAN's Avatar
Default valentine hardwiring
I know I have seen someone before talk about hardwiring a valetine from the courtsey lights next to the rear view mirror. Anyone know which wire he is refering to? Or if any of you have recomendations of a switched wire to tap off.
Old Jul 4, 2003 | 06:45 AM
ruexp67's Avatar
Check the library. There is a good article with pix. I would not tap off the courtsey light, then it's on all the time. There is an open connector available on the fuse panel that is switched with the car.
Old Jul 4, 2003 | 06:57 AM
nownor's Avatar
The pics in the library don't come up too well. goto www.s2000.org and find it in the DIY mods section. It's really easy and literally takes like 30 minutes if you go really slow and carefully to install. the only thing extra you're gonna need is just a female quick disconnect that you can get at radio shack or home depot for a couple bucks
Old Jul 4, 2003 | 12:27 PM
J MAN's Avatar
Thanks!
That's what I was looking for.
Old Jul 4, 2003 | 07:11 PM
nownor's Avatar
no problem..any problems let us know..
Old Jul 6, 2003 | 07:14 PM
John_Z's Avatar
I hardwired my Passport 8500 to the fuse panel by the drivers left leg. I wouldn't recommend wiring the detector to the courtesy lights because you won't be able to wire an inline fuse from the hot lead to the detector. If something should go wrong with the connection your unit is toast. Just run the wire along the windshield trim down to the box. Check out this link
https://www.s2ki.com/forums/showthread.php?...?threadid=32749
s2krobert
Dec 19, 2007 04:49 PM
Willie Gee
Oct 31, 2006 08:16 AM
Mr. Francesco
Sep 25, 2005 11:42 AM
EVAN_In_A_SPA
Jan 9, 2003 12:38 PM
