vtec pressure switch bypass
Old Feb 23, 2012 | 05:59 AM
Phill24's Avatar
Default vtec pressure switch bypass
has any1 here ever tried bypassing the pressure switch?... found a few sites that says to wire it to the solenoid but thats on the civic/integra so im not sure if thats the route to go these are the sites i found
http://honda-tech.com/showthread.php?t=1693528
http://www.utahhondas.net/index.php?topic=11120.0
the reason for trying to bypass the switch is only to pass nyc inspection dont want to have to pull my sidewinder off..no i wont be going in to vtec when or if i find the correct way to bypass it just need to drive the car so the factory ecm wont throw a code
Old Feb 23, 2012 | 06:38 AM
camuman's Avatar
lemme get this straight. you dont want vtec to kick in at all while you have the stock ecu in? so dont go above approx 80% throttle and 6k rpms. bam vtec bypassed.
or do you have a piggy back on the car?
Old Feb 23, 2012 | 07:08 AM
Phill24's Avatar
No i had to remove the pressure switch because of my sidewinder...it throw a code 1259...in nyc if the light is on ur car fail...im currently on aem so i dont need the switch..with factory computer its looking for it
Old Feb 23, 2012 | 05:20 PM
Phill24's Avatar
??????? No1 has ever tried to bypass they're pressure sensor
Old Feb 23, 2012 | 05:52 PM
s2knoob89's Avatar
Remote mount the sensor with a oil line connected to it.
Old Feb 23, 2012 | 06:00 PM
D1sclaimer's Avatar
Doesn't it just ground out when pressure is above the setting? I believe it's just a simple Hobbs switch. Ground out the wire for the sensor and see how it works.
Old Feb 23, 2012 | 06:52 PM
siik_ap2's Avatar
i've done it the way that was done in the 1st link...on obd1 cars, never did it on an obd2 car tho...i dont see why it wont work, if you figure out the correct pins..
Old Feb 23, 2012 | 08:04 PM
Phill24's Avatar
Imma try it tomorrow hopefully it will work
Old Feb 27, 2012 | 06:31 PM
siik_ap2's Avatar
you happen to try it???
Old Feb 27, 2012 | 07:20 PM
Phill24's Avatar
No i didnt get the chance i ended up messing with my fuel lines
liquidgsr
Sep 19, 2012 06:06 PM
rog06s2k
May 21, 2012 05:47 AM
honda9krpm
Aug 12, 2005 02:49 AM
turbo_pwr
Sep 11, 2003 04:48 AM
1a-race
Jul 3, 2002 05:38 AM
