What is the best way to patch a hole in firewall?
Old Jul 22, 2009 | 06:53 AM
emerlin's Avatar
Default What is the best way to patch a hole in firewall?
I just installed a amp and car alarm and was wondering what is the best way to patch up a hole in the firewall? The hole isnt to big but I would like to cover it up with something just in case any water/heat gets in. Does anyone know what a good material to use to patch it up?
Thanks!
Old Jul 22, 2009 | 07:10 AM
DFWs2k's Avatar
is it one of the holes already there? or you drilled a new hole?
Old Jul 22, 2009 | 07:17 AM
emerlin's Avatar
well it was in a nissan 350z but its all the same.
Old Jul 22, 2009 | 07:41 AM
emerlin's Avatar
oh and yeha i drilled a new hole.
Old Jul 22, 2009 | 08:30 AM
oth's Avatar
oth
ideally you would put a grommet in the hole to protect the wires from
the metal, then I personally would use silicone caulk, though the
professional installers might have other suggestions.
Old Jul 22, 2009 | 10:57 AM
2big4aS2000's Avatar
fill with silicone.
Old Jul 22, 2009 | 12:23 PM
DFWs2k's Avatar
why did you drill a new hole?
Old Jul 23, 2009 | 05:55 AM
takeshi's Avatar
In descending order:
Grommet
Modified plug
Silicone
Old Jul 24, 2009 | 11:41 AM
emerlin's Avatar
thanks silicone hole it is =)
Old Jul 27, 2009 | 01:48 PM
S2KSuzuka's Avatar
What size is the hole?
Phoenix Gold (and I'm sure other manufactureres sell plastic compression fitting jsut for that purpose. the fitting has two treaded nuts. One is to secure it to the fire wall, and the other is the compression fitting with a rubber seal to seal up the wire.
any good Auto stereo place should have one. Of course you will have to disconnect the wires on one side to feed them through
watchdogd
Nov 3, 2009 05:26 AM
SimbaDogg
Apr 1, 2008 06:27 AM
watermelonman
Feb 12, 2007 06:05 PM
WindchaserS2K
May 23, 2006 10:10 AM
DJSang
Oct 16, 2002 01:46 AM
