when installing a new HU...
Old Jan 30, 2007 | 04:44 PM
gnehc1's Avatar
Default when installing a new HU...
should i connect straight to the battery or use the power line in the harness? i'm about to install the pioneer deh 780mp, and if i don't have to connect to the battery, it will be less work. thanks...
Old Jan 31, 2007 | 04:27 AM
ruexp67's Avatar
For a lower power HU, the factory power connection is fine. I believe some of the higher end Alpines require an extra line to the battery.
If you plan to Amp the HU, you can definatly use the factory power as the amp will take the bulk of the work away from the HU.
Old Jan 31, 2007 | 04:33 AM
YuriArts's Avatar
I also have an Alpine but connected to amps. then u can use the factory power connection.
without amps it shouldn't be a problem but Alpine say you have to so they don't get slaims when your car goes up in smoke
Old Jan 31, 2007 | 05:09 AM
itsmylittlebrothersbike's Avatar
What does the Pioneer manual say?
Old Jan 31, 2007 | 07:00 AM
darkknight1999's Avatar
That HU does not need to be feed from the battery. You can use the harness power.
Penforhire
Jul 25, 2008 11:24 AM
B.Money
May 14, 2007 10:29 PM
krbz
May 30, 2006 07:10 AM
docbry
Apr 27, 2004 08:50 AM
peterbanks
Jun 1, 2003 05:56 PM
