Where did you ground your ground wire?
Old May 13, 2009 | 08:24 AM
Boost76's Avatar
Default Where did you ground your ground wire?
Where did you ground your ground wire? Where is a good place to ground the ground wire? Just want to know my options from those whose done it. Where is the best possible place? Thanks in advance. Pics welcome.
Old May 13, 2009 | 09:14 AM
2big4aS2000's Avatar
ground wire for what?
Old May 13, 2009 | 09:28 AM
DFWs2k's Avatar
the chassis
DFWs2k's Avatar
for a more specific answer, more specific information is needed
Old May 13, 2009 | 09:55 AM
Boost76's Avatar
I'm sorry, I meant for the amps in the trunk. Where did you all find a good connection? I'm running a mono block MTX amp & I seem to be having ground issues. I'm getting frustrated. So I'm asking the forum where they grounded their's. Mine is currently grounded on the bottom left bolt of the trunk when you remove the covers to access the fuel pump. With a small amp it seems fine but the the mono bloack I'm not sure if I'm getting enough ground.
Old May 13, 2009 | 10:07 AM
Tripleblackap1's Avatar
I have built many custom stereo systems. It is best to ground the wire to the chassis. But, before you do sand off the paint. This will make a better connection. The paint actually creates some resistance and can cause a ground loop.
You may need to have bigger power wire and ground wire. I would get a bigger ground wire first.
Old May 13, 2009 | 10:17 AM
SgtB's Avatar
Rear cross brace bolt.
Old May 13, 2009 | 10:37 AM
Neutered Sputniks's Avatar
Bad call.
There are so many layers of rust inhibitor and paint, along with the welded nut (welds aren't exactly great conductors) makes that a not-so-good mounting point. And, yes, I know, everyone here does it. That doesn't make it right. Everyone here is into Class-D full-range amplifiers - but few realize the sound difference a quality AB amplifier makes. There are a lot of Alpine Fan-bois too. Doesn't mean Alpine's the greatest product out there (in fact, their F1 line isn't even made by them!)
The BEST ground is a brass screw threaded into a purpose drilled/tapped hole in the chassis with all the layers of paint/primer/rust inhibitor dremeled off the surrounding area.
Old May 13, 2009 | 11:27 AM
SgtB's Avatar
I believe you. I'm also curious how much more capacity we're talking about. It may be negligible for low to mid power setups. I might do some testing on the amp draw on two different points.
Old May 13, 2009 | 11:40 AM
DFWs2k's Avatar
I'd be curious to see the results.
