Where to drill hole for Ipod in glovebox
Old Oct 26, 2005 | 05:12 PM
cpatel529's Avatar
Default Where to drill hole for Ipod in glovebox
I am planning on moving my IPod that i have in my MY2000 S2K into the glovebox. Where do I drill a hole in the rear of the glovebox to work the wires through? How large should the hole be? Do I need to remove the entire glovebox to do this? And if so, any online help to do this? Any help would be much appreciated. I have been searching online for a help guide and reading posts but couldnt find any direct information for what I seek.
Chirag
Old Oct 26, 2005 | 06:42 PM
darkknight1999's Avatar
Well depending on which glove box your going to use(upper or lower) will decide on where to drill the hole. However either way there is no need to remove it. You can drill the hole from inside the trunk.
Old Oct 27, 2005 | 09:48 AM
C4SxM5's Avatar
no need to drill if you are sticking in the bottom. i stick my ipod on the door with the spandex holding it in place and the wire can go through the door crack. it closes fine to.
Old Oct 27, 2005 | 11:55 AM
patinum's Avatar
I did not drill at all. I ran the cable through the gap near the door hinge.
Old Oct 27, 2005 | 12:05 PM
C4SxM5's Avatar
I was trying to say the samething concerning my install but its sounds more complex. LMK if u need pictures
Old Oct 27, 2005 | 06:07 PM
JSfetko's Avatar
Same here! NO holes drilled.
Old Oct 29, 2005 | 10:24 PM
Incubus's Avatar
I still have the RCA connector (no link to control from radio) and the cable is THICK. I'll see if it fits through the crack.
cpatel529
Sep 1, 2005 04:31 AM
djs94124
Nov 24, 2004 09:49 PM
User 53024
Oct 17, 2004 03:18 PM
funnyesq
Jun 22, 2004 07:50 AM
rworne
Sep 11, 2003 12:36 PM
