where to run speaker wire to make it look professional?
Old May 15, 2001 | 07:25 AM
CRussel's Avatar
[QUOTE]Originally posted by MacGyver
When g-s2k was helping me with mine, I was worried this would be major reconstructive surgery.
Old May 15, 2001 | 07:53 AM
g-s2k's Avatar
Originally posted by josh3io
along the same lines, how to run power from the battery to the trunk???
Alright, Lets start off in the engine bay...
Over by the battery, if you remove the clamp that holds down the battery and slide the battery towards the engine a couple of inches, you will see a grommet to the left, below the battery tray. Take a sharp object like a X-Acto knife and poke a hole in this grommet.
Now open up your passenger side door, and start removing all of the trim panels around the door.
Next remove the passenger side seat.
Un-bolt the seat-belt bolt on the floor
Remove the plastic panel on the back wall of the passenger compartment (looks like a vent and has the hooks for the net storage thingie).
Lift up all of the carpet (as best you can)
And now you have clear access to run your power wire for your amplifier.
Just remember to place a fuse within 12 inches of your battery, and a ground point as close as you can to the amplifier.
And for a little tip running your power wire through the rubber grommet in the firewall (if you have trouble getting it through). Get a small mixture of water and dishwashing soap and coat the first couple inches of the power wire, and that should do it!
Another little tip: Try and keep the power wire away from the speaker wire. BUT... If the speaker wire does have to cross over or under the power wire, try your best to have it cross at a 90 degree angle.
If you run into any problems let me know! Good Luck and Have Fun!
Old May 15, 2001 | 08:31 AM
Rex's Avatar
Rex
g-s2k's instructions are good. You can find the changer installation instructions here:
http://www.handa-accessories.com/S20...nger.pdf<br />
Old May 15, 2001 | 08:43 AM
g-s2k's Avatar
[QUOTE]Originally posted by Rex
[B]g-s2k's instructions are good.
Old May 15, 2001 | 06:41 PM
josh3io's Avatar
had everything down but where to go thru the firewall. thanks!!!
s2kvsall
Jun 9, 2009 07:56 PM
plutonium239
Nov 1, 2007 09:24 AM
InsaneInNC
Sep 9, 2003 10:35 AM
145
Mar 17, 2003 03:53 AM
145
Jun 29, 2002 08:01 AM
