will this start a fire?
Old Jun 27, 2008 | 06:42 PM
shotgunjimmy's Avatar
Default will this start a fire?
so i got my order in today (HU, speakers, 10g wire kit to amp the speakers, and 8 inch 70w rms powered sub.)
the sub came with its own wiring harness, which is basically like a HU harness, just with longer wires. it has its own specific plug that connects it to the amp. the power wire in this harness is only about 10 feet long, and im not sure that will reach from the battery to behind the drivers seat. after seeing that, i intended on connecting the power wire for the sub, to the power terminal on the amp for the speakers.
i called crutchfield.com's support, and they guy i talked to was a retard, so im getting a second opinion.
will what i have planned cause any problems with any of my equipment or create any fire hazards?
if possible, PM me your response or at least to let me know you posted a reply as i plan to install this tomorrow and would like to get some suggestions. thanks!
james
Old Jun 27, 2008 | 07:17 PM
oth's Avatar
oth
best would be to get a distribution block like this:
http://www.knukonceptz.com/productDe...prodID=BC-1428
power wire from the battery goes to the block, then one wire goes
to your amp, and one to the powered sub.
this also allows you to separately fuse each wire off the block, which is
important because the powered sub likely has a smaller wire than your
wire from the battery, so it needs a smaller fuse (it may be that there's
already a fuse in the wire leading to the sub).
HTH
EscapePod
May 4, 2018 02:46 PM
DangerZone9K
Mar 4, 2011 05:31 AM
CeleSaga83
Jul 3, 2007 06:51 AM
Kenpo_S2000
Oct 30, 2006 08:44 PM
J Nick
Nov 5, 2004 06:21 AM
