Wiring both DEI motion and shock sensors
My clifford matrix came with the DEI shock sensor, but on one end warn away and full alarm are wired together, and on the other end the full alarm wire (blue) is left cut. I could not get warn away to work no matter what.
I just bought the 508D motion sensor too. How do I wire both in correctly? There is a connector for one sensor on the control module and also a multiplex input on the main harness.
there is no way to have the harness on backwards because the connectors are different on each end. If someone has put both sensors in successfully please let me know how you wired both sets of 4 wires.
the wire that your seeing is the output - your talking about the green wire correct?? the side that's looped is going to go into the sensor , and the other wire is used if you wanted to hook up another componet such as the siren that talks , so when stage one is set the output of the green wire sends a power and the siren would say "back away" or whatever. now you should have gotten a daisy chain with the motion detector and you just hook that up the same way.
the green wire from the BRAIN, should be spliced into your motion sensor. Use the green AND blue wire from the motion sensor and splice into the one green wire from the brain and also splice the + and - as well.
if your alarm is a dei unit with an lcd screen, then the blue wire will indicate sensor 1 and the green wire will indicate sensor 2 on your remote
o wait i realized all three wires can be multiplex. finally found the place in the manual. to make wiring easier here's what i'm doing. radar will only tap into the main harness, so power and ground and both green and blue to the thick wires. the shock sensor will remain unchanged. i don't want to be feeding so much power on that thin 22or 24ga wire
