Wiring Problem?
Old Apr 6, 2009 | 09:41 PM
SgtB's Avatar
Some decks have a fuse on the remote. Is that good? Make sure any fuses stuck in the rear of the deck are good too.
Old Apr 6, 2009 | 10:18 PM
Stealth_SUX_'s Avatar
dude u need a multimeter. go pick a cheap one up at sears and come back and post.
Old Apr 7, 2009 | 12:31 AM
Truvietz916's Avatar
I Do have one but we pretty much figured out that it's the remote lead wire. So now i'm asking how do I fix it.
Old Apr 7, 2009 | 09:58 AM
yea the point of the multimete is to see if the deck is still putting out the 12 volt signal. cause if it is than u have a cut or pinched wire somewhere. U need to start at that...
You can hook the remote wire to the acc on in the car but ur gonna get a loud popping sound everytime you turn it on. So its best to use the multimete and see if its putting out 12volt at the deck. Make sure u cut the remote wire off and then just test it at the deck, incase the remote wire is grounding somewhere.
Old Apr 7, 2009 | 11:20 AM
Haha this is a lot of work. It's a lot of work pulling out the deck and tucking the wires nicely to get the deck back in. But I will hopefully have time this weekend to check on that. Thanks for the help.
P.s if the deck isn't putting out 12v for the signal is there anyway to fix that?
DDuds2k
Aug 13, 2007 05:13 PM
overkill
Apr 24, 2004 05:49 PM
h0ckeypunk
Feb 22, 2004 06:11 PM
145
Jul 9, 2002 06:06 PM
virtualtom
Jun 6, 2001 08:13 AM
