Wiring Speaker Wire from Amp to Stock Wiring
Old 04-09-2014, 06:30 PM
braeden's Avatar
Default Wiring Speaker Wire from Amp to Stock Wiring
Title pretty much sums it up. Is this wise? I don't believe I'll ever be pushing out the maximum power of the amplifier but I kinda wanna make sure it's idiot proof for any future owners.
I've basically soldered the speaker wires from the amplifier to the stock speaker wiring (FL+,FR+,FL-,FR-)
I know my best bet is to run the speaker wire through the door grommet and connect it straight to my Hertz crossovers but that seems like a massive pain in the ass.
tl;dr, can I get away with this for now/forever or should I man up and run the speaker wires directly through the door?
Hoping this question hasn't been asked before
Braeden
Old 04-09-2014, 07:15 PM
Sylvan's Avatar
Look, it's actually pretty easy to pull wires through the door grommet. Just take a stiff coat hanger and straighten out one end. Reach inside the door from the speaker opening, place the pointy end of the coat hanger into the rubber wire bundle, and carefully push it through until it penetrates into the footwell area. Then bend the tip into a hook, use that to attach your speaker wire securely with some electrical tape. Apply some grease to the speaker wire and pull the coat hanger back out the speaker hole. Presto.
Attached Thumbnails Wiring Speaker Wire from Amp to Stock Wiring-image-2782176597.jpg   Wiring Speaker Wire from Amp to Stock Wiring-image-3337699036.jpg   Wiring Speaker Wire from Amp to Stock Wiring-image-2692253309.jpg   Wiring Speaker Wire from Amp to Stock Wiring-image-1164892468.jpg
Old 04-09-2014, 08:45 PM
braeden's Avatar
Thanks man, I'm an audio engineer by trade so I'm not used to doing a shitty job when it comes to anything audio related.
I'll have to solder on another metre or two to the left door (passenger), but other then that should all be good.
Cheers
Old 04-10-2014, 06:21 AM
2big4aS2000's Avatar
unless your running 200+ watts to each door the factory wires are fine - you will never hear the difference.!
han racer
08-01-2007 03:43 AM
Red_Devil
05-07-2006 01:18 AM
s2k330
11-20-2005 02:14 PM
J Nick
03-23-2004 06:03 PM
InsaneInNC
09-09-2003 10:35 AM
Quick Reply: Wiring Speaker Wire from Amp to Stock Wiring
