Wiring your S2000's new ICE setup
Old Jul 19, 2006 | 07:15 PM
  #131
ttang's Avatar
I have a question about grounding the HU. Isn't the antenna the ground already?
  #132
ttang's Avatar
Old Jul 19, 2006 | 07:28 PM
  #133
darkknight1999's Avatar
No not really You must properly ground the headunit, to the steel of the car. The body panels don't count
Old Nov 8, 2006 | 02:31 PM
  #134
slanguage's Avatar
i noticed in one of the pics the wire was feed into the trunk on the passenger side. i just got a sirius plug and play radio and wanted to run the antenna wire into the trunk to mount on the back of the car between the trunk and top. is there a hole like that on the drivers side?
Old Nov 8, 2006 | 02:45 PM
  #135
Yup sure is. But there's a lot of power running on the side of the car though.
Old Nov 8, 2006 | 03:02 PM
  #136
slanguage's Avatar
Thanks
Old Jul 7, 2008 | 08:17 PM
  #137
azianbboi85's Avatar
ok so after i run the power wire from the driverside, how do i move it over to the passenger side to where the spare is. under the dash behind the headunit?
there seems to be no opening connectint the drive and passenger side without cutting a panel to run though?
can anyone get some detailed pics.
i want to run a small 450w system but im afraid my battery will die out faster.
anyone run into weak battery problems yet?
Old Jul 7, 2008 | 08:26 PM
  #138
Run the wire into the trunk down the drivers side then you can install the power wire to where ever you need to once its in the trunk.
Old Jul 8, 2008 | 12:40 PM
  #139
oh ok, i just thought the only opening to the trunk was on the passenger side.
thanks darkknight
Old Jul 8, 2008 | 02:40 PM
  #140
Yeah there's an opening on both sides.
No problem
