06+ with Flashpro p2101 when hitting 8800rpm
Old May 29, 2012 | 05:43 PM
  #31
GrandMasterKhan's Avatar
uploading edits to the overrun settings. lets see how many explodes I can get into tonight.
Old May 29, 2012 | 08:18 PM
  #32
no dice w overrun set to 9500. It kills the throttle right at 8800.
Old May 31, 2012 | 05:09 AM
  #33
spectacle's Avatar
Interesting problem. Hondata's latest post seems to hint that they are aware of a potential cause but my guess is the fix could be something they could implement in a software update. Hope you guys get this straightened out.
and LOL @ Wadzii with AEM fix lol! you really do dislike Hondata haha
Old May 31, 2012 | 05:35 AM
  #34
wadzii's Avatar
Banned
lol, at least when an aem ems does something other than what I tell it to do we KNOW there is something wrong and can send it back. With hondata.. its supposed to do things you dont tell it to do..
Old May 31, 2012 | 07:23 AM
  #35
Gernby's Avatar
Former Sponsor
I don't think Hondata hinted at a fix at all, since he said that the S2000's throttle behaviour can't be modified at all.
Old May 31, 2012 | 09:25 AM
  #36
spectacle's Avatar
Originally Posted by Hondata
Tested this today and can confirm that the error is generated by the throttle control module and is not related to rpm. I held the rpm over stock rev limit for some time and did not get the error until I manually levered the throttle plate (which is quite hard to do btw).
Now I'm really confused. Since this is an n/a car, we know the problem isn't related to pressure. Now they're saying its not related to RPM...so what is it? How do you this...
The error code is generated by the throttle control module when the actual throttle plate position does not match the target throttle plate (by 4-6 degrees)
...if the FlashPro cannot change throttle behavior? Does the ECU command the throttle module to move a certain percentage? Seems impossible with this statement:
Our policy is not to change the behavior of the throttle apart from the target throttle table, but with the S2000 we cannot change any of the throttle control as it is handled by a separate module under the dashboard (not part of the ECU).
Something doesn't add up.
Old Jul 15, 2013 | 10:51 AM
  #37
rrthorne8's Avatar
having same issue all of a sudden. Throttle plate starts to close around 8200 even though cammand is 100. at 8430 is goes into limp mode with code
Old Jul 15, 2013 | 10:52 AM
  #38
wadzii's Avatar
Banned
Our issue turned out to be the alternator. Voltage was dropping at high rpms
Old Jul 15, 2013 | 11:41 AM
  #39
Gernby's Avatar
Former Sponsor
I've received 2 emails about this issue today! The throttle plate sticks at 9%, and the engine dies. I’m guessing both were due to a glitch in a beta version of FlashPro Manager.
Old Sep 15, 2013 | 12:29 PM
  #40
LJD's Avatar
LJD
Any resolution on this issue? I just received my Hondata Flashpro and installed the software in anticipation of performing the "stock Hondata reflash" later this evening or later this week. The software prompted me to download beta version 1.6.1.0, but I stuck with the current 1.5.6.0 version for now in light of these posts. Please advise which version I should proceed with. Thanks.
