View Poll Results: What tuning system do you run and prefer?
Voters: 537. You may not vote on this poll
AEM ems vs Hondata
Since Hondata still gives us the finger on any type of failsafe measure, would hooking up a boost solenoid and then programming it to bleed boost from the diverter valve be an effective measure when the AEM Failsafe detects a lean condition and triggers the failsafe ground?
Say between 8-9k leaking even 1 psi would be able to help smooth out if it goes .5-1 lean right? Im definitely looking into experimenting with the option since nothing really exists for us kpro dudes. The other possibilities with the failsafe were to ground out afew spots but the optimal thing to ground doesnt seem to be known to tuners ive spoke to.
Any chance the bosch valve would be of any use? I just want it to drop enough boost when activated to take it outta the danger zone if that happens to occur. I had the Turbonetics Godzilla on there but took it off cause I got tired of the noise.
