AEM v1 hunting idle on warm start?
Old May 8, 2016 | 02:54 AM
amdaman's Avatar
Default AEM v1 hunting idle on warm start?
Hi,
Is there something I can adjust to stop the revs hinting on a warm start? It settles down eventually but it's annoying as hell. It doesn't do it on a cold start. Any clues?
Thanks
Old Jul 17, 2016 | 07:21 AM
Ian300D's Avatar
Are you talking about the AEM 1052?
Have you already tried, https://www.s2ki.com/s2000/topic/246...h-the-aem-ems/
Old Jul 17, 2016 | 01:55 PM
amdaman's Avatar
hi - cheers, my idle is a steady 950 once it settles. It's just when I warm start it plays up before it settles down.
It's just an annoyance really.
Old Jul 25, 2016 | 02:14 PM
kabaroo's Avatar
I am fighting idle surging. Idle is set higher I'd guess 1200 to 1300. Surges from 1200 to 2500 back and forth. Thought it was iacv but that was cleaned and seems to function fine. I can get it to settle at 1200 if I lightly engage clutch and ease it down.
1000 Id injectors and haltech on e85.
Old Aug 22, 2016 | 04:17 AM
Ian300D's Avatar
Id say because you are out of range of your IACV. Why do you want that high of idle. My friend has a aggressive cam and still at 850-900rpm. And injector size doesn't matter heads up. Try following my guide to adjust your idle and values.
https://www.s2ki.com/s2000/topic/115...le-fix-finally
mikefifth
Dec 7, 2014 04:50 AM
S2KVee
Sep 26, 2014 07:08 AM
AusS2000
Nov 14, 2010 09:44 PM
camuman
Aug 22, 2009 02:08 PM
Urge
Apr 13, 2005 02:05 PM
