AEM v2 starting problems
Old Aug 21, 2015 | 03:18 AM
UH-60DRIVER's Avatar
Default AEM v2 starting problems
So my car starts fine the first start of the day. If I drive it for more than 30 minutes and turn it off it doesn't want to re-start for 30-45 minutes. After it cools off it starts up just fine again. It's running a AEM EMS v2 and I have also done a fuse box relocation under the dash. Not sure if it's wire related of EMS related. Thanks
Old Aug 21, 2015 | 04:01 AM
Che2K's Avatar
I'm having the same problem also. I was told that it's a tuning issue.
Old Aug 21, 2015 | 06:12 AM
superchargedk20's Avatar
Worth a shot.
https://www.s2ki.com/s2000/topic/883...efiningtuning/
Old Aug 21, 2015 | 09:08 AM
yamahaSHO's Avatar
Generally it's cold starts that give issues. This should be an easy fix... It'll need more or less fuel at the coolant temperatures you are experiencing the hard starts.
Old Aug 21, 2015 | 10:43 AM
R u still on stock injectors ? I used the settings listed above car started Everytime . Cold or hot. Then I got retuned with a different start up tune and still no issues.
Old Oct 25, 2015 | 02:01 PM
blink962's Avatar
bad wiring connection? did you play on any wire?bad ground?
AWWHITE s2k
Oct 6, 2023 06:19 AM
S2kserry
Feb 3, 2014 04:04 PM
AWWHITE s2k
Nov 2, 2012 12:50 PM
Metcalfe
Sep 10, 2011 07:57 AM
Sukeetoshyoo88
Jan 21, 2010 05:26 PM
