aem v2 vs aem infinity
They owe royalties. However, stating that doesn't change the fact that the Infinity is not ready to replace the v2.
And... They still haven't received an update in a long time considering its their current, top ECU. The higher models have gone even longer than the model used for the S2000
I run an Infinity in my Integra and it is pretty awesome . In my S2k i run a v1 Aem . Not even close between the two . All the various systems out there do have there little bugs . I'd say use what your tuner knows .
Some do not like to start with the resync safeties turned on. It also interprets spark blowout as cam/crank sync error... Then timing is a guess. This is a 770whp/700wtq 95 Taurus SHO.
We checked for timing drift and that seemed to track fine.
I havn't had issues with timing(that I know of) but I have had the infinity not reference the boostduty cycle and it didnt reference the failsafe boost cut. Car hit over 30psi and fell hard. I assume it blew the spark out. Only happen once, but that once could have destroyed the motor if it had a large frame turbo on it
