Can any emanage gurus look at this map?
I wasn't able to get in boost today because of traffic but I was hovering around 120-130's which is a little higher than you. Seems like you are good. I actually have the SoS upgraded heat exchanger sitting in the garage so hopefully that will help bring them down a bit.
I use my vista laptop for tuning. I can get the software to work with my windows 7 laptop but the damn usb drivers won't work. I did have some trouble with the install though. Did you try uninstalling?
His program is not with the program its with the USB driver. Reboot and before windows 7 starts to load hit F8. Then when it comes up highlight Disable Force Driver Signature and then boot Win7. This will allow the drivers to install like they are suppose to
I have windows 7 64bit, the problem is with screen formatting etc. I have changed the resolution, ran in compatibly mode and tried all sorts with no avail.
I cannot for the life of my via the axis on the maps properly.
