Can I remove the Vtec Oil pressure switch while using Kpro?
Old Jan 19, 2014 | 07:38 PM
S2Kid91's Avatar
Default Can I remove the Vtec Oil pressure switch while using Kpro?
Hey guys, did some searching and could not find much on this. I have a custom sidewinder manifold being made for my Ap1 currently and I was looking at clearing the passenger side of my bay. As Im sure many of you know the Vtec oil pressure switch plug protrudes a fair amount over the manifold, I was wondering if i can remove the switch and block off the port while using Kpro. I know this is possble with Haltech and AEM, but being that I have to be able to pass emissions Im forced to run Kpro. Any help would be much appreciated.
Old Jan 19, 2014 | 09:16 PM
crxdx's Avatar
Plug it with a m10x1.25 bolt trimmed down to the same size as the threads on the sensor and tell your tuner to disable the sensor.
Old Jan 20, 2014 | 03:59 AM
S2Kid91's Avatar
Thats what I was wanting to do, but I wanted to check and make sure Kpro does not need it. I know AEM and Halltech dont require you to run it, but I had someone telling me they thought Kpro needed the Vtec oil pressure switch still.
Old Jan 20, 2014 | 04:19 AM
crxdx's Avatar
It's in vtec parameters just uncheck "vtec oil pressure switch enabled"
F1TwoThousand
Jul 17, 2018 01:26 AM
Forcedbird
Aug 18, 2016 10:02 PM
Bryce1115
Mar 10, 2013 02:44 PM
jphish
Nov 13, 2006 04:48 AM
