Check Engine code Mfg Control P1457 $0010N
Old Jun 18, 2023 | 10:27 AM
Matt_in_VA's Avatar
Community Influencer
Default Check Engine code Mfg Control P1457 $0010N
My check engine light came on on my 2003 AP-1 with the following code: Manufacturer Control P1457 $0010N
Anyone know what would cause this? Any suggestions as to what I should do about it?
Old Jun 20, 2023 | 08:51 AM
Tech Engineer's Avatar
The ECU pulls a vacuum on the gas tank and monitors if the vacuum can be held; if it doesn't, P1457 is registered.
Old Jun 20, 2023 | 02:37 PM
Matt_in_VA's Avatar
Thank you for the reply. Is it possible that my gas cap needs to be replaced after twenty years?
Old Jun 21, 2023 | 03:10 AM
Sure, a gas cap that doesn't seal well enough will cause this code to register.
Old Jun 21, 2023 | 05:53 PM
Matt_in_VA's Avatar
Thank you. That would be an easy fix.
topcat7111
Sep 24, 2009 04:39 PM
flopez82
Sep 7, 2008 08:03 PM
maxum8504
Mar 4, 2008 06:47 PM
gt2690b
Jul 5, 2005 10:59 PM
