checking air fuel ratio from data logging on flashpro, how accurate?
hey guys, i decided to datalog my s2000 today just to see how everything looks. im actually pretty new at this but i noticed that my air fuel ratio during WOT was around 10.14 and 12.25 (corrected)
I am confused what the difference between the two are. i did a bit of searching but didnt have any luck, other than they both will be different from each other.
my current set up
2006 s2000
sos stage 2 supercharger with 9psi pulley
rc650cc injectors
berk 63mm high flow cat
divert-er valve is dispensing to atmosphere
stock cluck and flywheel
91 octane
tuned from a very reputable shop in so cal
here is a screenshot of what i am talking about. throttle plate is 100%
shed some knowledge on me guys, i dont want to blow a motor lol
also temp outside was 93 and i smelled my dipstick and no smell of gas!
my current set up
2006 s2000
rc650cc injectors
91 octane
Look at the AF.Corr value on your sensor list on the left. It's showing 12.25:1. It's pretty accurate to within a couple 1/10's. However, as you go richer, the reading decreases in accuracy. For WOT, you want to look at this corrected value.
Data log a WOT you're run to redline, and PM me. I will check it for you if you're worried.
Thank you so much. I had a feeling this was the case but I needed someone else to verify. I just ran a 3rd gear wot and my afcorected ratios are looking good.
are the air fuel ratios off because of the o2 sensor on the 06 doesnt actually read correct unlike if i get an aftermarket bosch one?
No problem.
Who better to explain it, then Hondata themselves. Here ya go:
http://www.hondata.com/help/flashpro...correction.htm
