DBW throttle plug
Yep looked into that and it's £2-300 over here for a loom. A lot of money for what is basically a £5 connector at the most! Would be nice to just find the connector as it must be made by one of the main companies. I guess it must be the same as the ones on the civic etc!
Honda uses a lot of sumitomo connectors, see if you find the part number
This is a good source to connectors in small quantities:
http://www.easternbeaver.com/Main/El...SMHW/smhw.html
I've given up looking for a honda plug, I have ordered a used vw golf R32 throttle body and pedal assembly. Just got to make a couple of adapter plates to fit but easy really. Also both of those bits are half the price of just a used honda dbw throttle body. Plus the r32 one is 80mm so it will suit my plenum as it's machined out to 74mm already.
mroverkill
Sep 16, 2015 06:08 PM
