DBW throttle plug
Old Feb 17, 2014 | 11:56 AM
mattie170's Avatar
Default DBW throttle plug
Does anyone know where I can buy the plug for the DBW throttle as I am wanting to convert over to one?
Matt
Old Feb 18, 2014 | 12:52 PM
GrandMasterKhan's Avatar
you are going to need A LOT more than just the plug. YOu have to have the ECU, throttle controller, engine harness. TONS of work.
Old Feb 18, 2014 | 12:58 PM
mattie170's Avatar
I'm running a motec M800 so won't need any of the other honda parts. I would like to run a honda dbw throttle so just need a plug to make the loom up.
Old Feb 18, 2014 | 01:26 PM
06Estukay's Avatar
Find a scrapped 06+ wiring harness, chop off the connector.
Old Feb 18, 2014 | 02:07 PM
mattie170's Avatar
Yep looked into that and it's £2-300 over here for a loom. A lot of money for what is basically a £5 connector at the most! Would be nice to just find the connector as it must be made by one of the main companies. I guess it must be the same as the ones on the civic etc!
Old Feb 18, 2014 | 02:27 PM
06Estukay's Avatar
It will be the same for the Civic, correct. Also the TSX and accord too. The newer J35/J37 dbw engines also use the same connector. See if you can find a scrapped car at a wrecker's. Should be easy to find.
Old Feb 18, 2014 | 02:42 PM
mattie170's Avatar
Will have to see what else runs it over here in the uk. Still be nice to just find a brand new plug with pins.
Old Feb 18, 2014 | 03:03 PM
afzan's Avatar
Honda uses a lot of sumitomo connectors, see if you find the part number
This is a good source to connectors in small quantities:
http://www.easternbeaver.com/Main/El...SMHW/smhw.html
Old Feb 19, 2014 | 12:20 PM
mattie170's Avatar
I've given up looking for a honda plug, I have ordered a used vw golf R32 throttle body and pedal assembly. Just got to make a couple of adapter plates to fit but easy really. Also both of those bits are half the price of just a used honda dbw throttle body. Plus the r32 one is 80mm so it will suit my plenum as it's machined out to 74mm already.
sunman
Feb 27, 2019 04:49 PM
mroverkill
Sep 16, 2015 06:08 PM
Bobby_Digital
Nov 18, 2013 07:49 AM
sapone
Jun 28, 2011 03:07 PM
Sub-Zero
Florida For Sale
Jan 8, 2009 06:26 AM
