Disable Evap in kpro
Old May 4, 2010 | 09:13 PM
benlee02's Avatar
Default Disable Evap in kpro
Is there a way to disable the evap system in the kpro? Do i even need the evap system?
Old May 4, 2010 | 09:31 PM
DFWs2k's Avatar
pretty sure it's automatically disabled, if you are talking about the airpump thing in the front bumper
Old May 11, 2010 | 08:17 PM
96-EJ6's Avatar
EVAP and the airpump are different systems.
I believe the EVAP system (this purges fuel tank vapors back in to the intake manifold for emmissions purposes) still functions normally with the K-Pro. There is no advantage to disabling it. Hondata chime in???
The airpump ("injects" fresh air into the exhaust to help bring the catalytic converter up to operating temperature faster and thus reduce emissions on cold start) is automatically disabled by using the K-Pro ECU. You may remove the airpump and associated components without getting a CEL.
Old May 12, 2010 | 06:57 PM
benlee02's Avatar
Well i dont care about emmissions so is there a way to disable EVAP?
Old May 12, 2010 | 07:04 PM
96-EJ6's Avatar
I'm not positive if it is disabled with the rest of the OBDII functions or not...anyone else know?
Old May 13, 2010 | 04:07 AM
JustinC's Avatar
im pretty sure evap doesn't work on the kpro considering that you use the evap solenoid to actuate boost control inside of Kpro
Old May 13, 2010 | 09:06 PM
benlee02's Avatar
well when i removed it to clean up the engine bay, i got a check engine light. i guess i have to put it back on.
Old May 14, 2010 | 04:03 AM
JustinC's Avatar
interesting, must be because you have the obd2 checking on
Old May 14, 2010 | 11:14 AM
spectacle's Avatar
I have obd2 turned on with a boost controller and I throw no CEL
realblag
Mar 12, 2019 06:54 PM
Corey Maurer
Apr 3, 2012 05:03 AM
theblackpearl
Jun 6, 2009 02:23 PM
zakiu
Feb 23, 2008 12:18 PM
typer0085
Jun 8, 2004 05:52 AM
