ECU pins
Old Mar 2, 2010 | 10:50 PM
AusS2000's Avatar
Default ECU pins
I have an AEM EMS and am adding various sensors to it. They need to be wired in to certain pins on the ECU plugs.
My question is, which way up do the new pins go? I know you have to lift the white part first but I can't seem to get existing pins out nor properly secure new pins.
So, firstly, are these the right pins and secondly which way up do they go?
This way:
Or:
Old Mar 5, 2010 | 06:13 PM
96-EJ6's Avatar
To extract pins you will first need to lift the white "lock" that secures the pins in the connector, it just pops up a few mm. Next find a small sharp pick, the pick will be used to lift the second clip that holds each pin in the connector individually. Hold the connector so the wires are away from you and look closely at the individual pins, You'll see the silver pin toward the front then a tiny plastic clip on top of it a bit farther inside the connector, your goal is to GENTLY and CAREFULLY lift this clip away from the pin while at the same time GENTLY pulling on the wire that's attached to the pin your extracting. Be patient, it takes time and touch to get the hang of it, the wire/pin will come out very easily when you get it right.
The second photo is the correct orientation I believe, if they're upside down they just won't click in to the connector with no harm to either.
Old Mar 5, 2010 | 06:17 PM
D1sclaimer's Avatar
That is correct. The second picture is the right way to do it.
Old Mar 7, 2010 | 03:03 PM
AusS2000's Avatar
Thanks guys, that is exactly what I needed!
Old Mar 8, 2010 | 03:20 PM
DFWs2k's Avatar
where do you get ecu pins and is there anything else you can use if they can't be found? i'm having such a difficult time sourcing them
Old Mar 9, 2010 | 04:21 PM
96-EJ6's Avatar
Just PM me your address and how many you need, and I'll mail them to you for free. I have tons of old connectors laying around I can extract them from if you don't mind having them already assembled with a pigtail.
Old Mar 10, 2010 | 11:20 AM
DFWs2k's Avatar
^thanks, that wouldn't be in enough time, trying to get everything done before friday
Old Mar 10, 2010 | 08:17 PM
96-EJ6's Avatar
Ahhh, that sucks! Isn't T1 (Tony Palo) tuning your car??? If that's that case I'm sure he'll have some.
Old Mar 10, 2010 | 08:39 PM
AusS2000's Avatar
Yee haww!!
Thanks guys!
Old Mar 10, 2010 | 08:46 PM
96-EJ6's Avatar
Originally Posted by AusS2000,Mar 10 2010, 09:39 PM
Yee haww!!
Thanks guys!
LOL very nice! Just takes A LOT patience and a little time. Now the rest will be cake.
ihiryu
Apr 24, 2014 08:02 AM
xredjar
Sep 2, 2011 04:20 AM
Gaspode
Feb 21, 2009 10:31 AM
dmw16
Mar 22, 2007 05:29 PM
REV_29K
Mar 1, 2005 10:12 PM
