Flashpro : Blank datalog file
Old Jan 9, 2015 | 03:04 PM
Seanix's Avatar
Default Flashpro : Blank datalog file
Has anyone had an issue with FPM loading a blank file?
My flashpro has the datalog but when I download and safe it to my laptop, it's just a blank file.
I data logged 7 calibrations but for some odd reason, datalog-4 is a 1kb file when saved to the harddisk.
All the other datalogs are okay.
I've tried to re-export the datalog file on numerous attempts but still no luck.
I'm starting to think this is a FPM glitch. Anyone else had this issue?
Thank you.
Old Jan 9, 2015 | 07:12 PM
06Estukay's Avatar
Yeah, this happens once in awhile with FP. I've been using all of the builds since I got it in 2011, and had corrupt logs from time to time regardless of build. You can send the corrupt file to Hondata. They will try to recover the data, and send it back to you. However, I only bothered to do it once.
Old Jan 9, 2015 | 08:42 PM
Seanix's Avatar
Thanks for ur feedback
I ended up redoing the datalog. What a pain in the ass.
I'll make sure I check the file size each time I download a datalog moving forward.
Old Jan 20, 2015 | 09:04 PM
Seanix's Avatar
quick update:
i data logged several calibrations last night. on 3 separate occasions, FPM downloaded blank files
the files exist on flashpro but FPM downloads a 1kb file.
so i now datalog for a few seconds first and then do it the second time. this seems to prevent the blank files as they generally seem to be happening on the first attempt.
researching further online reveals that this may be a common problem. hopefully Hondata address this issue.
Old Jan 21, 2015 | 07:57 PM
06Estukay's Avatar
Originally Posted by phearable
I have never seen such an issue.
If the issue purists after restarting the laptop/software shoot hondata an email with the details of the bug & I am sure they will resolve it asap if it is an issue.
support --=at=-- hondata.com
Then you probably haven't done very much datalogging with Flashpro. I've easily done 100+ hours of datalogging with my Flashpro. I usually get a corrupted log for every 25 good logs. The problem IS common among other users. The laptop and/or software has nothing to do with the problem. The data is getting corrupted on the FP.
You're sure they will resolve it ASAP? This is Hondata we're talking about. Good luck with that.
Old Jan 22, 2015 | 05:32 PM
Seanix's Avatar
are you using the BETA version by any chance?
i was recommended not to use it as it tends to play up more often.
its frustrating when you go through the effort of datalogging and end up with a useless file.
Old Jan 22, 2015 | 09:45 PM
06Estukay's Avatar
I've had the problem with both official and beta releases. More so on some releases than others, but I wasnt keeping notes. Just accepted the fact that a log would screw up now and again.
Old Jan 27, 2015 | 05:36 AM
badboy00z's Avatar
I've had that problem a few times. It's so annoying.
boltonblue
Jan 5, 2014 05:18 PM
s2kdriver80
Apr 24, 2011 09:53 PM
JustinC
Oct 30, 2007 02:22 PM
Matt_in_VA
Apr 2, 2006 05:48 PM
PeaceLove&S2000
Jul 12, 2004 12:42 PM
