Fuel & spark trigger
Guys,
In a month or so I'll install my BC stage 2 cams with woodruff offset keys, +2 in/+2 ex, can someone confirm that the timing will be automatically advance 4 degrees and the fuel injection will also start earlier due to the ECU crank + cams position sensors monitoring, (cams sensors will be advance), thanks.
Guys,
Thanks Gernby, that is what I figure out but haven't read it black on white, I'll send you a before & after road log with some notes, I'll also install a PRM intake with the trumpet inside the fender with the fake bumper intake opened up.
Agreed, that will probably show me that my timing is slightly advanced, less than I thought because the offset keys will probably bring back the timing close to original compensating for chain stretch (retard)...
normally when you change cam timing ign timing changes as well.
Has anyone done any testing w/the +2 deg on both cams? I havent seen it posted.
