Fuzzy ECT / TPS
Old Apr 28, 2010 | 11:55 AM
kaissi's Avatar
Default Fuzzy ECT / TPS
[media]http://www.youtube.com/watch?v=1GchB7QSlLw [/media]
What could the problem be?
The AEM EMS 2 unit is working fine on a USDM S2000... but on a EDM version.. it does this.. we tried few EDM S2000 .. same problem..
erratic TPS / ECT...
Also on the USDM .. the engine starts from the first crank, on the EDM ones, it takes few cranks to start...!?!?
Old Apr 30, 2010 | 12:09 AM
kaissi's Avatar
Nobody can help ?!?!
Old Apr 30, 2010 | 09:49 AM
wadzii's Avatar
Banned
add some grounds, maybe unplug stuff one at a time and see when the readings smooth out.
When it all smooths out you found the problem
Old May 1, 2010 | 06:54 AM
kaissi's Avatar
I thought about the grounding issue at first.. but is it a coincidence..!?!
that on my friend's USDM it worked fine
on my EDM S and my friend's also EDM S... the same problem!?!?
And I took off the radio fuse, inside lights, many fuses.. to eliminate a potential grounding issue... same problem.
eastonh477
Dec 7, 2012 07:43 AM
HighwayStar
Aug 10, 2008 11:48 AM
AusS2000
Jan 26, 2008 05:58 AM
_Kjetta__
Aug 31, 2006 05:48 AM
124Spider
Oct 19, 2005 05:17 PM
