Giles E-Manage Ultimate
Old Mar 23, 2012 | 03:50 PM
zbrewha863's Avatar
Default Giles E-Manage Ultimate
I bought a Greddy E-Manage Ultimate (EMU) that was supposedly tuned by Giles. I am planning on installing it this weekend -- how do I know that the tune is on there? Is there a way to test this out and make sure everything is right before I hook it up, or at least before I apply the tune?
Nobody in my area is really a Greddy EMU expert, so there isn't a lot of local, professional help I can get here.
Old Mar 23, 2012 | 07:16 PM
liquid_helix136's Avatar
When I got mine, it had a sticker on it with its settings, and came with a manual from Giles' shop so it looked legit. I just plugged up the EMU to the stock ECU and turned the car on, everything worked fine and I noticed a bit of a difference. Power didnt drop off after 8k (ap1 here) throttle response and rev match downshifting was easier, a little better mpgs as well if i remember correctly.
You could probably hook it up to a laptop but you would need the software and the proper cable to hook it up. If it's on there, there should be a password protected map that you can delete, but not modify without the password. I dont have it anymore so I cant really tell you much more. Too bad he didnt lower vtec at all in those maps, because then it would be very easy to tell whether the map was on there or not lol
Old Mar 23, 2012 | 07:32 PM
zbrewha863's Avatar
Ok, I have no sticker on the E-Manage and no manual with it. I guess I will have to install the Greddy software on a laptop, plug it in, and see if there is a map on the E-Manage. Is there a special cable you need to connect to the laptop, or just any USB cable?
Old Mar 23, 2012 | 11:51 PM
I couldn't tell you. I never hooked mine up. Im sure someone else can chime in
Old Mar 24, 2012 | 04:36 AM
s2kS0L's Avatar
Haven't hooked mine up in a while, but I think it requires a type A and type B ended usb cable (similar to some usb printer cables).
Old Apr 10, 2012 | 02:55 PM
legend4life's Avatar
When you had the giles tune, was it only tuned for wot, or were there gains in and a good part throttle tune as well? Any idea how he got around the stock ecu fuel trims making changes?
Old Apr 11, 2012 | 09:25 AM
zbrewha863's Avatar
I honestly still haven't looked at it yet, I've been too busy. My understanding is that it is a tune across the board, not just for WOT. I have no idea how Giles tunes it, and he locks his tunes, so you can't play around with it.
Old Apr 11, 2012 | 05:04 PM
RedSunS2K's Avatar
I have a giles tuned, emu. I had it tuned by him last year. I will see if there is a sticker on it.
When I gave him the car, I'm pretty sure he said he had to open it and rework some stuff in the EMU itself. Also he mentioned that he does some work to the PnP harness.
https://www.s2ki.com/s2000/uploads/g...7516_55371.png
This is the dyno he emailed me with on my greddy kit. I feel like there's something wrong with my tune though as the tq numbers are strangely higher than most other Greddy turbos. Also the fact that it just drops after 6k.
Old Apr 11, 2012 | 06:02 PM
^^ lol I'd say that was a dyno to an STI or something but it revs out to 8.8k
GreenTuxedo
25
Jul 15, 2010 09:28 PM
myflys2k
Dec 10, 2009 09:03 AM
bae
Dec 3, 2008 08:44 AM
JSR_AP2
Sep 9, 2005 02:18 PM
Maca
Mar 13, 2003 02:32 AM
