Greddy Emanage Ultimate, communication questions
Old Dec 7, 2013 | 04:54 AM
flanders's Avatar
Default Greddy Emanage Ultimate, communication questions
Just got a second hand unit and installed it with a boomslang pnp harness, also latest software and drivers installed on my laptop.
Now I would like to connect to the unit and download the tune that is suppose to be there.
But when I turn ignition on it's still seems to be in offline mode, no led activity on the greddy unit either.
Does the car need to be started also?
Intake manifold is currently not installed so can't check myself
Old Dec 8, 2013 | 12:55 PM
s2konroids's Avatar
You need ignition on, no the car doesnt have to be started/running.
Sounds like its getting no power, there should be led lit on it.
Old Dec 8, 2013 | 09:44 PM
flanders's Avatar
Ok thanks, I will check all the wiring and fuses.
The computer seems to recognice the EMU when I connect the USB though, I get the option to do a "Main Unit Update".
I'm scurred to do that though beacause I'm not sure if I will loose the tune installed.
Old Dec 10, 2013 | 10:55 AM
flanders's Avatar
I have no voltage on the ecu pin with ignition on, not sure why.
Did connect the EMU to my bench power supply and it starts and communicates fine, no problem importing the tune either.
Will deal with the voltage problem later when manifold is back on and all the sensors connected.
Old Dec 10, 2013 | 12:47 PM
s2konroids's Avatar
I'd get the tune and update with the 2.23 F/W - or whatever the last one was, think it was 2.23
Old Dec 10, 2013 | 01:01 PM
flanders's Avatar
Computer software is 2.30 but I think the unit had 2.23 and it did ask me to update firmware, I will probably do that later.
Old Dec 13, 2013 | 10:48 AM
james0933's Avatar
sorry it's off topic, but do you guys know how to get the drivers to work with windows 8?
Old Dec 14, 2013 | 02:01 AM
flanders's Avatar
I don't think you can, it's Windows 7 or preferably Windows XP.
Colonelkev
Jan 15, 2013 11:34 AM
9krevvin
Oct 3, 2010 05:15 PM
Tyraid2K
Jan 14, 2008 05:48 PM
jdnissanz
Nov 22, 2005 01:37 PM
S2000_Europe
May 21, 2004 07:29 AM
