AEM f/ic
Old Nov 28, 2013 | 02:39 PM
justin77's Avatar
Default AEM f/ic
I haven't really seen anyone mention the aem piggy back controller (fuel/ignition controller). Anyone use one before? They make a model just for the s. As far as piggy backs go it looks really good with the ability to data log, use a lab top, vtec engagement and such. I am just looking for an economical option to get a little more power for some bolt on's and maybe bc 2 cams. I know more power can be made by adding timing with standalone but for under $400 this seems like a viable option.
Old Nov 29, 2013 | 06:04 AM
1nate7's Avatar
General feeling is that it's complete junk. Some of the low boost F/I guys have had some success with it, including me, although I wouldn't really recommend it. Low boost is what it was designed for and it's basically useless for a good N/A tune because you can't advance timing, only retard it.
Old Dec 11, 2013 | 06:25 PM
jh4db536's Avatar
You're going to spend more in tuning than that unit itself. Same with the ems, you will have to drop a grand so you might as well do it right the first time; there's no economical options. Ems, haltech, kpro all require pay to play.
Sent from my SGH-T889 using Tapatalk
Old Dec 16, 2013 | 11:35 AM
s2000Junky's Avatar
Tried it years ago. A well known tuner in my area called Carb Connection couldn’t get it to work right, and that was after hours of assistance from AEM and 3 separate tuning visits. Closed loop/partial throttle was the issue they couldn’t get sorted out. I blame the unit compatibility and the tuners inexperience with the device an S2000. It ended up fuel washing my motor and I was shit out of luck. Tuner blamed it on the earth shattering 10psi Comptech kit I was running on my stock healthy motor
jln66
Jul 30, 2011 12:15 PM
purekoryo
Dec 30, 2010 08:18 AM
TerminatioN
Oct 20, 2010 10:28 AM
slizzle
Mar 6, 2009 11:08 PM
AssassinJN
Nov 8, 2006 07:43 AM
