Haltech vs Kpro?
Which one is better and why? I saw that Evans now has a set up using the haltech sport 1000. From my understanding it works in conjunction with the stock ecu which would help on the start up map problem the aem has. Is the sport 1000 as good as Kpro? This would be a awesome solution to not having to change all the sensor and such.
I'm also looking at Haltech vs. Kpro.
Can The Sport 1000 be tuned for altitude adjustment?
I live in UT, so I can go from 4,000 ft. to 10,000 ft. in about twenty minutes. It was mentioned that the KPro can be tuned to adjust via the ECU's altimeter. If the Haltech unit can do this, then I will definetly be going with it. That way my car can be easily returned to stock if I sell it.
finding the answears should be easier here... https://www.s2ki.com/forums/index.php?showtopic=829133
Originally Posted by Evans Tuning,Dec 27 2010, 09:47 PM
There is no direct baro compensation control with KPro. Your primary o2 sensor will trim the mixture in closed loop so the tune is consistent within normal driving conditions.
turbo8765
Dec 19, 2011 03:19 PM
