Haltech vs Kpro?
Old Dec 23, 2010 | 05:40 AM
josh7owens's Avatar
Default Haltech vs Kpro?
Which one is better and why? I saw that Evans now has a set up using the haltech sport 1000. From my understanding it works in conjunction with the stock ecu which would help on the start up map problem the aem has. Is the sport 1000 as good as Kpro? This would be a awesome solution to not having to change all the sensor and such.
Old Dec 23, 2010 | 07:13 AM
DFWs2k's Avatar
it depends on what your tuner is most comfortable with, i think evans was working on a harness for the haltech to be OBDII, but AFAIK, it's not completed yet
Old Dec 23, 2010 | 07:23 AM
josh7owens's Avatar
It's listed on his site now.
Old Dec 23, 2010 | 07:57 AM
DFWs2k's Avatar
ok, then there goes that argument for kpro, and it comes down to what your tuner prefers/is most comfortable with, obviously it'd save the installer some hassle, as you noted
Old Dec 25, 2010 | 07:41 PM
brax_1's Avatar
I'm also looking at Haltech vs. Kpro.
Can The Sport 1000 be tuned for altitude adjustment?
I live in UT, so I can go from 4,000 ft. to 10,000 ft. in about twenty minutes. It was mentioned that the KPro can be tuned to adjust via the ECU's altimeter. If the Haltech unit can do this, then I will definetly be going with it. That way my car can be easily returned to stock if I sell it.
Old Dec 26, 2010 | 10:05 PM
keemaca's Avatar
finding the answears should be easier here... https://www.s2ki.com/forums/index.php?showtopic=829133
Old Dec 27, 2010 | 06:35 AM
brax_1's Avatar
I'll repost there. Thanks for the link
Old Dec 28, 2010 | 07:52 AM
Gernby's Avatar
Former Sponsor
Originally Posted by Evans Tuning,Dec 27 2010, 09:47 PM
There is no direct baro compensation control with KPro. Your primary o2 sensor will trim the mixture in closed loop so the tune is consistent within normal driving conditions.
Whether you are at sea level, or 10K feet, the ECU will adjust fuel based on the MAP signal. According to Hondata, fuel trims are never applied during open loop on Hondas.
Old May 10, 2011 | 02:17 PM
Urge's Avatar
Sponsor
Can the haltech control ITBs?
__________________
Old May 12, 2011 | 04:24 AM
sohc_mshue's Avatar
Haltech is much more capable than kpro. I wouldn't even think twice about going to that instead.
turbo8765
Dec 19, 2011 03:19 PM
purekoryo
Dec 31, 2010 07:38 PM
Burt Reynolds
Sep 16, 2008 10:32 AM
rai
Apr 20, 2005 08:02 AM
supaman
Feb 28, 2004 11:59 AM
