Help setting base timing
Old Jun 1, 2018 | 10:38 AM
redboosteds2k's Avatar
Default Help setting base timing
Im setting up base timing using AEM series 2. there is a few marks on the crank pulley red and white. are any of these tdc and or 10 degrees? i dont have access to alldata at moment. Thanks.
Old Jun 1, 2018 | 10:43 AM
White=TDC and Red=5 btdc ? i have had mixed info during searching
Old Jun 1, 2018 | 04:35 PM
AP1Chief's Avatar
Aim the light toward the pointer {A). Check the
ignition timing under no load conditions:
headlights,b lowerf an, and alr conditionera re not
operating.
lgnition Timing:
5 degrees +- 2 BTDC (RED mark )) at idle in Neutral
if you need any tuning help LMK
92gli
Sep 2, 2018 06:41 AM
Ap1s2kay
Jun 15, 2016 04:33 AM
C4SxM5
Mar 2, 2006 06:38 PM
Sideways
Jan 16, 2005 04:34 PM
KYS2000
Jan 18, 2004 11:20 PM
