How to identify ghost knock
Old Dec 10, 2018 | 05:42 AM
  #31
CTRLFRK's Avatar
Sorry in advance for bumping an old thread but did anyone find a solution to this? I have the same issue and my ignition map ended up looking like it had a huge hole in it to get it to not knock and I verified I have good compression. About to switch everything back to stock because I don't want the ECU pulling timing from false knock. If anyone found a long term solution to this, please share it.
Old Dec 10, 2018 | 03:48 PM
  #32
CTRLFRK's Avatar
I solved my ghost knock today and wanted to post back. Either removing my spare tire in the trunk, an oil change, a valve adjustment or tightening down my battery heat shield (which was really loose) and bending my battery heat-shield TOWARDS the motor (it gets bent away during valve adjustments to get cylinder 4 exhaust side by accident and I'm sure it happens to others. Prior to today, i was getting really high ghost knock counts, almost 300 in 30 minutes. These were the things I changed and just drove it hard for 30 minutes with not even one ghost knock. Just wanted to post back my findings. Take care.
pjinadasa
May 7, 2015 05:54 PM
liquid_helix136
Dec 7, 2012 09:32 AM
Disgustipated
Oct 27, 2010 11:16 AM
Gernby
May 27, 2010 11:09 AM
tze
Oct 23, 2000 07:30 PM
