S2000 after head gasket replacement wont start plz help
ok guys i need some help with my s2000 I re did the head gasket after it got too hot and warped a bit .. my car is a e85 built 1200 cc injector clinic injectors .. AEM fuel rail fuel pressure regulator .. AEM V3 ECU ... T4 turbo with Greddy boost controller and other stuff .... now the engine is put back together ... Problem - We had to by pass the fuel relay to get the fuel pump to fire .. which i figured a bad relay .. second now we have fuel in the rail but the injectors are not firing .... it wont start... is there a cam sensor or crank sensor i m missing .. or is there something that i m missing which causes it not to start ... I m lost here ... please help
There are two cam sensors on the cam cover. Be sure they are plugged up. Check your cam timing. Most of the non-start issues are due to cam timing.
I would reverify timing. Best pics are in the stckies (Blue pinned top of Forum). FAQ, DIY, Maintenance. Go to "engine". 3 or 4 from the bottom of the list is a thread about DIY Retainer Replacement. It has the information you need to recheck the timing. Being off a tooth is "common" do in part to timing chains stretching a bit.
Utah
Utah
JakexTrainer
08-07-2021 02:53 AM
