ITBs with KPro Alpha-N
Old Mar 19, 2015 | 04:21 PM
  #21
Gernby's Avatar
Former Sponsor
You need to drive my civic to see how stock-like ITBs can be! The MAP based tune with DBW is friggin' amazing!
Old Mar 31, 2015 | 07:54 AM
  #22
rwheelz's Avatar
Originally Posted by Gernby
Originally Posted by rwheelz' timestamp='1424908529' post='23519380
My ITB AP1 was tuned via Alpha-N and it was garbage. Much easier to just put the IACV in place and tune it properly based on manifold pressure.
Any tune can be garbage, even a MAP-based tune. With a standard MAP block, a MAP-based tune is VERY difficult to get right, and it would not really be very streetable.
However, with the new type of MAP block that I developed for my URGE DBW ITB kit, a good MAP-based tune is totally achievable. I was actually able to pass the OBDII inspection with just 1 incomplete readiness code and no DTC's!
Sure, any tune can be garbage, but Alpha-N tunes are more likely to make your car run erratically- changes in elevation, weather/air pressure, extreme swings in temperature, etc I experienced it all.
My car ran great on two different vacuum blocks- the TIDUS block that was limited production, and also the URGE designs vacuum block. Both used the OEM MAP sensor. Both were entirely street able once tuned properly, so I am not sure why you would say a MAP-tune is not very street able.
What is different about your newly designed vacuum block as compared with the one sold by Urge over the past year?
z3lai
Mar 19, 2014 09:12 AM
goofball123321
Sep 29, 2011 06:36 PM
08s2000CRbackinblack
Jun 27, 2010 01:26 PM
Stratocaster
Aug 22, 2005 10:43 PM
