Kpro, AP1, Injectors not pulsing.
Old Feb 4, 2014 | 08:01 PM
2d-ink's Avatar
Default Kpro, AP1, Injectors not pulsing.
So I got Kpro for my 2002 AP1,
I'm getting sparks and i can hear the fuel pump priming.
but when I go to start the car the injectors isn't firing.
I uploaded the PRA s2000 calibration into the ECU
i'm on stock injectors.
with the ignition in the 2nd position.
i'm getting 11.8V on all 4 injectors clip.
I havent had time to pull any codes yet.
but does anyone have any idea why my injectors arent firing?
I pulled the spark plugs and they are bone dry.
Old Feb 5, 2014 | 07:20 AM
booost02's Avatar
This may be a stupid question but you are using the s2000 Kpro and not the RSX unit, correct?
Also, did you change the necessary sensors: crank sensor, and cam position sensors I believe? Hondata will have the correct list on their website
Old Feb 5, 2014 | 08:02 AM
2d-ink's Avatar
Yes I am using a PRB ECU converted to S2000 by Hondata. and yes I am using all the Kpro crank wheel, sensor, cam wheel, sensor and 06 valve cover.
Old Feb 5, 2014 | 08:08 AM
96-EJ6's Avatar
What does the k-pro say the injector pulse width is while cranking? Are these new or used injectors? How are you determining there is no pulse?
Old Feb 11, 2014 | 10:07 PM
2d-ink's Avatar
I figured it out. Thanks you. CLOSE thread
Old Feb 12, 2014 | 08:17 AM
Spunkster's Avatar
Why don't you enlighten everyone with what the issue actually was?
Old Feb 12, 2014 | 06:51 PM
s2kt3's Avatar
Ya seriously
Old Feb 15, 2014 | 08:00 PM
2d-ink's Avatar
I called Hondata and they walked me through trouble shooting it. I seriously dont remember we went through like 6 different trouble shooting then I went and try to start it and it started right up.
4x4 freak
Jan 31, 2015 09:54 AM
gbduo
May 2, 2014 05:38 AM
Gernby
Jan 17, 2012 09:04 AM
Chris_K
Nov 10, 2011 09:25 AM
Kevbo1983
Nov 12, 2010 04:04 PM
