Kpro help?
Old Jun 19, 2015 | 02:04 PM
blixhavn's Avatar
Default Kpro help?
I recently got hondata traction control and am about to install it.
I've already used the A30 pin to wire my wideband gauge in, which is the same place they want you to wire the orange wire from the traction control unit into. Is this going to confuse the ECU? Or can you have both inputs on the same wire? If not is there a secondary option for either the gauge or the traction control?
Old Jun 20, 2015 | 04:41 AM
ninetysixyenko's Avatar
what version of Kpro?
Old Jun 20, 2015 | 05:50 AM
JUSTINTHECOASTIE's Avatar
Upgrade to kpro 3 or better if you haven't already
Old Jun 20, 2015 | 08:10 AM
blixhavn's Avatar
I believe it is a V2, I bought it new 3 years ago if that helps?
What does the upgrade do?
Old Jun 20, 2015 | 08:44 AM
Kpro 3 gives you 8 more analog inputs, Kpro 4 has that and more, upgrade cost is $250...I recall turn around time is quick too
Old Jun 20, 2015 | 09:51 AM
You definitely can't have two things wired into the ELD wire. I haven't wired a traction control setup, but if that's what it requires, you need to wire the wideband elsewhere. If you spend the $250+shipping to upgrade to v4, you can wire a wideband into 1 of 8 analog inputs, and use it to run closed loop. Turn around time is 48 hours once hondata has received it. Plan on a week from sending it out to receiving it back.
You can tell what version you have by taking the cover off. V1 & v2 are green boards, v3 is red, v4 is white.
Old Jun 21, 2015 | 06:52 AM
blixhavn's Avatar
thanks fellas!
Old Jun 21, 2015 | 07:19 AM
afzan's Avatar
What's new in Kpro v3 https://www.hondata.com/kpro_v3.html
What's new in Kpro v4 https://www.hondata.com/kpro_v4.html
Kermdaddy
Apr 4, 2014 12:21 PM
flexer
Feb 1, 2009 07:10 AM
chillout18
Dec 12, 2008 09:37 PM
1-S2k-2-NV
Nov 17, 2005 10:14 PM
swtazn97
Sep 20, 2003 02:48 PM
