kpro problems
Old Mar 22, 2010 | 09:42 AM
civiccoupehybrid's Avatar
Default kpro problems
i just got a brand new kpro installed in rsx ecu
but i have some problems with it
when i try to load calibration into ecu,the engine stops also if i push "upload changes to ecu"
to upload a full calibration takes minimum 40seconds
and the realtime update is not working,because if i change anything,it does not go to ecu just if i push "upload changes to ecu"
can you tell me what to do now?
thank you
Old Mar 22, 2010 | 10:53 AM
got the answers from hondata.
no real time on kpro
Old Mar 22, 2010 | 01:00 PM
spectacle's Avatar
Kpro does not have real time updating. Turn the car off before you upload a kal. The car will die if you try to upload a new kal while its still running.
Old Mar 22, 2010 | 05:22 PM
S2kAndTheAnt's Avatar
I don't want to start a new thread. I'm running with the stock kpro basemap and all I have are J's racing headers. After I installed everything, on the way home my temp would rise 1-2 bars and a CEL would come on. Eventually I was easy on the throttle and the temp went back to normal when I got up to highway speeds and my CEL went away. I was wondering if this is normal? Will this go away after a tune?
Old Mar 22, 2010 | 05:29 PM
DFWs2k's Avatar
sounds like something else is wrong w your car, what was the code?
Old Mar 22, 2010 | 06:38 PM
I'll have to look at it later, my code reader is at my shop.
Old Mar 22, 2010 | 06:42 PM
DFWs2k's Avatar
kpro reads them too
Old Mar 22, 2010 | 07:15 PM
Originally Posted by DFWs2k,Mar 22 2010, 06:42 PM
kpro reads them too
Where would I find that in the kmanager software?
Old Mar 22, 2010 | 07:19 PM
DFWs2k's Avatar
do you have kmanager on your computer?
there is an error code button all the way to the right on the line that the "New Calibration" button is on
Old Mar 22, 2010 | 07:20 PM
DFWs2k's Avatar
or in the "window" menu, ctrl+6
