kpro problems
Old Mar 22, 2010 | 07:58 PM
S2kAndTheAnt's Avatar
Thanks! Its too late for me to drive anywhere right now, but I'll do it first thing in the morning. Also, the temperature dropped when I was idling at a red light or stopped for a bit. I added more coolant and double checked my hoses before everything went back in.
Old Mar 22, 2010 | 09:10 PM
DFWs2k's Avatar
ok, i dont even know if you'd have to drive around to pull it if it stored it?
idk how kpro works with codes that don't stay on though
Old Mar 23, 2010 | 08:30 AM
spectacle's Avatar
Kpro can display codes that cause a CEL, but not if they go away.
If the car is throwing a code with a CEL, plug up your laptop and go to the errors tab. The code number and name will be displayed. You can clear the code from here as well, but if the cause isn't fixed it will show up again soon thereafter.
Old Mar 23, 2010 | 10:10 AM
Okay I'm getting a P0217, Engine overheating. My kmanager shows the error, even though the CEL is not on.
Old Mar 23, 2010 | 10:13 AM
DFWs2k's Avatar
ouch not good
Old Mar 23, 2010 | 10:15 AM
DFWs2k's Avatar
oh if you dont replace the IAT, it says temp reads about 30 degrees higher, did you replace that sensor when doing the install?
Old Mar 23, 2010 | 10:34 AM
Yep, I did replace it.
Old Mar 23, 2010 | 10:39 AM
In the parameters menu, under protection. I had Generate P0217 overheating error code checked. I'm quite sure this is the cause of everything.
Old Mar 23, 2010 | 10:49 AM
spectacle's Avatar
What was your ECT threshold set at?
Old Mar 23, 2010 | 10:51 AM
DFWs2k's Avatar
mine's on and it wasn't overheating
