Long cranking time to start
Old Oct 19, 2020 | 06:28 PM
Telefunken72's Avatar
Default Long cranking time to start
I just had a supercharger kit with AEM infinity installed on my 01. Is it normal to take a lot longer for the car to start? My tuner said the Infinity will cause that as it has to run through a bunch of checks. It currently takes about 5-7 seconds to start. Is this normal?
Old Oct 19, 2020 | 07:28 PM
afzan's Avatar
Yes that’s normal. Almost all standalone ECU’s do that
they use a generic starting strategy that works on many motors but takes longer vs OEM ECU which use a very specific strategy for that specific motor
Old Oct 20, 2020 | 05:31 PM
joes sled 2000's Avatar
On my s2k i run Aem v1 and it takes about 3 seconds to start . On my Integra i run Infinity and it takes about the same 3-4 seconds . 5-7 seconds seems a little long .
Old Oct 20, 2020 | 05:33 PM
DutchyFutch's Avatar
Pretty normal yes.
Old Oct 20, 2020 | 07:30 PM
afzan's Avatar
true I assumed he exaggerated in his post
Old Oct 21, 2020 | 03:42 AM
Actually I timed it. About 6 seconds cold engine. Its a little less when engine is hot. Ive seen others with a aem v2 and it didn't take nearly as long.
Old Oct 21, 2020 | 04:52 AM
flanders's Avatar
6s doesn't sound right, I would worry about wearing out the starter prematurely.
Tune probably needs some more work.
Old Oct 21, 2020 | 05:47 PM
EOE's Avatar
EOE
1. Log it at a stone cold start
2. Log it at an operating temp start
3. Send logs to me or share on here via screenshot. We want to see sync time in seconds followed by crank time after successful sync.
7 seconds is too long even with AEM Infinity. Other ECUs offer pre-start delay to build oil pressure. AEM infinity does not offer such feature so there isn’t a tick-box that you might have ticked so... yes tune related it sounds like.
On a cold start sync should not take longer than 3 seconds from my experience. Once synced it shouldn’t take longer than another 2 seconds to fire.
Old Oct 21, 2020 | 06:11 PM
The Infinity does not prime the pump until it is cranking thus it takes maybe a second longer to start over a V1 or V2 Aem .
Old Oct 21, 2020 | 07:17 PM
afzan's Avatar
it's very easy to change that setting:
