Modified TODA tune loaded...any recommendations?
Hi,
I have an 06 with the following mods (in chronological order):
1.-FlashPro engine management
2.-Tanabe Medalion Touring 60mm exhaust.
3.-K&N FIPK intake
4.-Invidia 60mm test pipe
Before buying the Test Pipe, I had my car set to Stock tuned with VTEC engaging at 5300 RPM. However, after adding the Invidia Test Pipe, I have loaded a modified TODA calibration which consists of the standard TODA calibration (4100 RPM vtec point,etc) and turned off the seconday O2 sensor.
The driveability of the car has increased tremendously with noticeable more TQ and HP throughout the power band.
Do you think there will be considerable gains to be made from a custom tune? If I do some datalogging and post my maps will any of you be able to tell me where I have pottential for improvement?
Thanks in advance for the feedback.
3.-K&N FIPK intake
i ran the toda reflash just fine on stock header with just cai and tp. the the ap2 low cam flows very well up 5k+. now i have flashpro w/I/H/E and run vtec at 4800. i tried lower settings but nothing earth shattering in gains or losses... so pick you number and tune the a/f.
I also run the toda tune but it need some tweeking to be perfect so I do see that there could be some gains from a custom tune esp. On a dino to dile in the ign. But a e tune is a great value and should also see gains in top mid and drivability
dave_t
Dec 3, 2011 09:14 AM
06Estukay
Jul 20, 2011 09:58 PM
